Example Code
Median and Quartile Calculator (Q1, Q2, Q3) using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This VI calculates the first second and third quartiles (Q1, Q2, Q3) based on the third method dicussed here: http://en.wikipedia.org/wiki/Quartile
The second quartile can also be called the median.
There are multiple ways to calculate quartiles, this only implements one of them..
Description
 LabVIEW does already have a VI for calculating the median (called "Median.vi"), but it was convenient to include a G implementation of it here.
Requirements
  1. LabVIEW 2014(or compatible)
Just Input the data and run the VI, you can see the Q1, median and Q3 output.
Block Diagram
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
