Digital I/O
9401 driving a SSR
Is a 9401 module capable of driving a small (5amp) SSR with a 4-15 volt input?
(3,925 Views)
Technically yes, since the NI 9401 can ouput 5 V, but that is not what it is meant to be used for.  You're better off buying a cheap power supply (like 10 dollars) then just making a circuit that controls that power supply with the NI 9401.
What is your application and why are you looking into the NI 9401?  NI offers help with specing out systems.
1 (800) 531-5066
-Bear
Ben Johnson
ʕง•ᴥ•ʔง
(3,900 Views)
Well, basically I'm trying to repurpose an existing test rig and I've no choice but to use the hardware on hand. It was to be used to turn a motor on and off. I think I've answered my own question because I found the input on the relay draws 15ma and I don't think the 9401 will output that.  I wanted to do it cheap 'n dirty but now I'm thinking I'll have to use a BLDC motor and using the 9401 to generate a PWM signal to the controller. A tad more complicated but doable.
Thanks for the input
(3,891 Views)
Accepted by topic author GDthomas
You should consider using a buffer chip that can output the current you need, like this one.  This will require a 5V power supply, but it does the job.
(3,885 Views)
Acually the more I thought about it the more advantages I could see to switching to a BLDC motor mostly being able to control the speed. I'll have to see what happens. If it doesn't work out I'll definetly look into the buffer chip.
(3,879 Views)
