DQMH Consortium Toolkits Feature Requests
FabiolaDelaCueva
Make the API Tester not stop in case of error
Status: Released
Thank you for your suggestion @FabiolaDelaCueva 😉
Case #767 was created.
The problem I want to fix:
I want to be able to try to fix or poke the code more when an error occurs in the API Tester. The opportunity of going to the block diagram or attempting to send a different request goes away because the API Tester, by default, closes when an error occurs.
How I propose fixing it:
The first thing that I change on an API Tester at the first error is to remove the OR connected to the stop terminal in the loop and add an error indicator at the end instead of the Simple Error Handler and connect a local variable for the error. Would you please vote to have DQMH do this by default and have a validator to modify existing API Testers?
Current API Tester:
Proposed change:
Fab (yes, being the DQMH Lead Architect does not guarantee that all my wishes are turned into reality 😉 )
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
1 Comment
Olivier-JOURDAN
Status changed to: Released
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
