03-29-2012 10:23 AM
I would like to view only the rows in which the data in column x is some particular value.
For instance, I'd like to view (and create a group of channels) containing only data from rows where the text in column 2 is MC1.
... guess I can't put a picture inline...
See attached for sample data.
Thanks.
03-29-2012 09:51 PM
Hi ebloohm,
If you'll post or email (brad.turpin@ni.com) an example data set, I'll send you code that does the row filtering.
Brad Turpin
DIAdem Product Support Engineer
03-29-2012 11:31 PM
Thanks Brad.
Will the screenshot of the data from the previous post work?
If not, I can send you a portion of the actual data file.
03-30-2012 06:37 AM
Hi ebloohm,
No, I can't test my script with your screenshot.
Brad Turpin
03-30-2012 09:08 AM
OK. A small sample is attached. The original file is about 1 1/2 million rows.
04-03-2012 10:16 AM
Hi ebloohm,
This script will break out your loaded data rows by the "Station" channel values. let me know if you want to filter out the "1;2" suffix or leave it differentiated. If you want to do the same sort of thing not within a single file but across multiple files, then you'd do better to change your DataPlugin to enable the DataFinder to pull only the desired rows from each file.
OPTION EXPLICIT
Dim i, j, iMax, jMax, RawGroup, Channel, IdChName, OrderChName, Msg, LastTime
Dim IdChDict, IdChannel, OrderChannel, RowDict, RowKeys, RowItems, DataChDict
IdChName = "Station"
OrderChName = "" ' "Time" or ""
Set RawGroup = Data.Root.ChannelGroups(GroupCount)
On Error Resume Next
Set OrderChannel = RawGroup.Channels(OrderChName)
On Error Goto 0
Set IdChDict = CreateObject("Scripting.Dictionary")
Set IdChannel = RawGroup.Channels.Add(IdChName, DataTypeString)
IdChDict.Add UCase(IdChannel.Name), IdChannel
Set Channel = RawGroup.Channels(IdChName) : IdChDict.Add UCase(Channel.Name), Channel
jMax = RawGroup.Channels.Count-1
Set DataChDict = CreateObject("Scripting.Dictionary")
IF IsObject(OrderChannel) THEN
DataChDict.Add UCase(OrderChannel.Name), OrderChannel
END IF
FOR j = 1 TO jMax
Set Channel = RawGroup.Channels(j)
IF NOT IdChDict.Exists(UCase(Channel.Name)) AND UCase(Channel.Name) <> UCase(OrderChName) THEN
DataChDict.Add UCase(Channel.Name), Channel
END IF
NEXT ' j
Msg = "Enumerating all the Groups..."
Call MsgBoxDisp(Msg, "MB_NOBUTTON", "MsgTypeNote", 0, 0, 1)
Call CreateIdChannel(IdChDict)
Set RowDict = EnumerateIdRows(IdChannel)
RowKeys = RowDict.Keys
RowItems = RowDict.Items
iMax = UBound(RowKeys)
LastTime = Timer
FOR i = 0 TO iMax
IF Timer > LastTime+1 OR Timer < LastTime THEN
Msg = "Sort Extracting Group " & i+1 & " of " & iMax+1
LastTime = Timer
END IF
Call ExtractIdGroup(RowKeys(i), RowItems(i), IdChDict, DataChDict)
NEXT ' i
Call RawGroup.Channels.Remove(IdChannel.Name)
Call MsgBoxCancel
Sub TextToNumeric(Group, ChanName, ChanType, Factor, Offset)
Dim RawChannel, NewChannel
Set RawChannel = Group.Channels(ChanName)
Set NewChannel = Group.Channels.Add("New|" & ChanName, ChanType)
L1 = RawChannel.Properties("Number").Value
L2 = NewChannel.Properties("Number").Value
ChnLength(L2) = ChnLength(L1)
Call ChnCalculate("Ch(L2) = CDbl(Ch(L1))")
IF Factor <> 1 OR Offset <> 0 THEN
Call ChnLinScale(NewChannel, NewChannel, Factor, Offset)
END IF
Call ChnMove(NewChannel, RawGroup.Properties("Index").Value, RawChannel.Properties("GroupIndex").Value)
Call RawGroup.Channels.Remove(RawChannel.Name)
NewChannel.Name = Mid(NewChannel.Name, 5)
End Sub ' TextToNumeric()
Sub CreateIdChannel(IdChDict)
Dim j, jMax, RawGroup, ChListStr, IdChannels, IdChannel
IdChannels = IdChDict.Items
Set IdChannel = IdChannels(0)
Set RawGroup = IdChannel.ChannelGroup
Call RawGroup.Activate
ChListStr = ""
jMax = UBound(IdChannels)
FOR j = 1 TO jMax
ChListStr = ChListStr & "Ch(" & IdChannels(j).Properties("Number").Value & ") & ""."" & "
NEXT ' IdCh
ChListStr = Left(ChListStr, Len(ChListStr)-9)
Call ChnCalculate("Ch(" & IdChannel.Properties("Number").Value & ") = " & ChListStr)
End Sub ' CreateIdChannel()
Function EnumerateIdRows(IdChannel)
Dim j, jMax, RawGroup, RawChannel, RawChnStr, RowDict, StartRow, StopRow, RowMax
RawChnStr = ""
FOR j = 1 TO jMax
Set RawChannel = RawGroup.Channels(j)
RawChnStr = ChnStrAdd(RawChnStr, RawChannel.Properties("Number").Value)
NEXT ' j
Call ChnMultipleSort(IdChannel, RawChnStr, 0, 1)
L3 = IdChannel.Properties("Number").Value
Set RowDict = CreateObject("Scripting.Dictionary")
StartRow = 1
StopRow = 1
RowMax = ChnLength(L3)
Do While StopRow <= RowMax
T1 = ChT(StartRow, L3)
StopRow = ChnFind("UCase(Ch(L3)) <> UCase(T1)", StartRow+1)
IF StopRow = 0 THEN StopRow = CLng(RowMax+1)
RowDict.Add T1, StartRow & "|" & CLng(StopRow-StartRow)
StartRow = CLng(StopRow)
Loop ' Until End Of Channel L3
Set EnumerateIdRows = RowDict
End Function ' EnumerateIdRows()
Function ExtractIdGroup(RowKey, RowItem, IdChDict, DataChDict)
Dim j, jMax, RawGroup, RawChannel, NewGroup, NewChannel, RawChnStr, NewChnStr, DataChannels, Cols
Dim StartRow, RowCount, NewDataType, NewDataDisp, NewOrderCh, IdChannels, IdChannel, OrderChannel
Cols = Split("|" & RowItem, "|")
IF UBound(Cols) < 2 THEN Exit Function
StartRow = CLng(Cols(1))
RowCount = CLng(Cols(2))
IF Data.Root.ChannelGroups.Exists(RowKey) THEN Call Data.Root.ChannelGroups.Remove(RowKey)
Set NewGroup = Data.Root.ChannelGroups.Add(RowKey)
Call NewGroup.Activate
FOR j = 1 TO jMax
Set IdChannel = IdChannels(j)
NewGroup.Properties.Add IdChannel.Name, ChV(StartRow, IdChannel.Properties("Number").Value)
NEXT ' j
RawChnStr = ""
NewChnStr = ""
DataChannels = DataChDict.Items
jMax = UBound(DataChannels)
FOR j = 0 TO jMax
Set RawChannel = DataChannels(j)
Set NewChannel = NewGroup.Channels.Add(RawChannel.Name, RawChannel.DataType)
ChnLength(NewChannel) = RowCount
NewChnStr = ChnStrAdd(NewChnStr, NewChannel.Properties("Number").Value)
NEXT ' j
Call DataBlCopy(RawChnStr, StartRow, RowCount, NewChnStr, 1)
NewChannel = ""
Set NewChannel = NewGroup.Channels("Value")
On Error Goto 0
IF OrderChName <> "" THEN
NewChnStr = ""
Set OrderChannel = NewGroup.Channels(DataChannels(0).Name)
FOR j = 1 TO jMax
Set NewChannel = NewGroup.Channels(DataChannels(j).Name)
NEXT ' j
Call ChnMultipleSort(OrderChannel, NewChnStr, 0, 1)
END IF ' can order the rows of each extracted Group
Set ExtractIdGroup = NewGroup
End Function ' ExtractIdGroup()
Brad Turpin
04-04-2012 08:40 AM
Thank you.
07-16-2014 05:05 AM
even if this topic is already a while ago this pretty looks atfter what i need.
But i have a few issues about the script from Brad_Trupin.
-Where in the script and how can i pretend according to which row (value) is filtered (so not for all row(values) will be filtered and created a group)
or even better after more pretende row values will be filtered (like in excel)
-How can i manage it that the filtered channels are not sorted (or sorted by time-channel/chronologically)
Thanks a lot
07-17-2014 09:55 AM
hello AndiMEC,
i'm not sure i understand what you're asking. say you have a column of numeric data, and you want to filter the data to show only numbers < 10. would like you like to filter it further or for it to maintain the original row placement? please clarify what you mean.
07-17-2014 10:53 AM
i juat want to get the same as in the script of Brad_Trupin is done only a bit modifyed.
Example i have 5 text channels and i want to filter them (like in exel), one channel includes the values M1, M2, M3 ,M4, and i want to filter after e.g M1 AND M3 (like in excel)
And how do i get it that the result channels aren't sorted (like in the original channel)
