DIAdem
How can I filter data by row contents? Similar to Excel's filter feature.
AndiMEC,
I see what you are saying now. In order to filter without having the sorted values, you will have to filter before sorting. Even in Excel if you filter after sorting, the original row placement is not maintained.
Message 11 of 14
(1,561 Views)
i don't  want to sort the valtues of a channels, the order must be kept as in the originall channels. It's only the filtering!
Message 12 of 14
(1,555 Views)
Hi Andi,
The short answer is that DIAdem does not make this easy the way Excel does.  You would need a custom VBScript to do the sorting for each type of logic (M1 OR M3) that you want to apply.  If you post or send me a data set, I could send you a simple VBScript that shows you how to do this, but I'm not convinced you'll be happy with this approach.
What do you think about the idea of doing your sorting in Excel and then loading the sorted values from Excel into DIAdem for further analysis and reporting?  Excel DataPlugins are easy to create.
Brad Turpin
DIAdem Product Support Engineer
Message 13 of 14
(1,519 Views)
Hi Brad,
thanks for your advice and help. But meanwhile i solved my problem otherwise because i already thought that DIAdem does not make this easy the way Excel does.
Message 14 of 14
(1,502 Views)
