DIAdem
Help creating a Graph using .SUD
I'm trying to plot data in a graph within my .SUD.
I'm trying to control the start time of each cycle of my data but I'm at a loss to find any examples how to do this.
Does anyone know or have an example of the commands explained for plotting graphs?
I have looked in the DIAdem Help section, but have had no luck.
Thank you in advanced.
shaun
Message 1 of 9
(5,125 Views)
Accepted by Spidermansrevenge
Hi Spidermansrevenge,
Please have a look at this example:
Greetings
Walter
Message 2 of 9
(5,096 Views)
Walter:
Thanks so much for you help again. Not sure how I missed this help example.
This should get me on my way!!
Always Very helpful
Thank you again !!
Shaun
Message 3 of 9
(5,080 Views)
I've used this example to get started with my own plot. Is it possible to programatically change the scaling of the X or Y axis? I see the option to change from linear to logarithmic, but I'm not seeing a way to say adjust what range of the X axis is plotted.
Basically trying to do this:
PlotA.XAxis.Scaling.Begin = 0
PlotA.XAxis.Scaling.End = 0.1
Message 4 of 9
(5,051 Views)
Hi Tamer,
You were pretty close.
Set Graph = Report.ActiveSheet.Objects("2DAxis1")
Graph.XAxis.Scaling.AutoScalingType = eAxisAutoScalingBeginEndManual
Graph.XAxis.Scaling.Begin = 0
Graph.XAxis.Scaling.End   = 0.1
Call Report.Refresh()
Brad Turpin
DIAdem Product Support Engineer
Message 5 of 9
(4,986 Views)
Thanks Brad, but doesn't that do the scaling in the report tab? I'm looking to scale the graph on the GUI.
Message 6 of 9
(4,952 Views)
Hi Tamer,
I thought we were talking about the REPORT panel.  If you mean the VIEW panel instead, there is one option to provide specific Y axis start and stop values:
Brad Turpin
Message 7 of 9
(4,937 Views)
Hey Brad. I've actually created a GUI with a 2D plot on it for quick plotting (Since using the viewer hasn't been resolved). I'm looking for a callout I can use in the sub of a button click to scale the 2D axis on the plot of the GUI. See screenshot attached.
Message 8 of 9
(4,933 Views)
Hi Tamer,
Are you saying that you're using a Curve2DPreview control on a SUDialog to make that graph?  If so, I don't see any method to specify the start and stop values of the X or Y axes for that control.  I only see the linear vs. logarithmic choice for each axis.
Brad Turpin
Message 9 of 9
(4,865 Views)
