DIAdem
Cannot establish Logos server
i have a problem with Diadem in my workplace. I have installed Diadem software on several computers and after starting Diadem i get this error -
DataFinder: My DataFinder
Version: 15.0.0f5998
The DataFinder cannot start due to an internal error.
(65): cannot establish Logos server
I just click on OK and everything starts as it should, but it's annoying for users. So please can you help me with this error. Thanks.
(6,585 Views)
Accepted by pikafirm
Logos is a National instruments Windows network service used for DIAdem - DataFinder inter process communication.
It is installed automatically when installing DIAdem and should be up.
  • Is it blocked by your IT?
  • Did something go wrong during installation?
  • Are there error messages when starting your PC up
If datafinder is not starting up and shouldn't do so it is possible to select a different content for DIAdem Navigator for startup.
Go to DIAdem Settings (Settings->DIAdem Settings) and set according to the screenshot.
You need to save your Desktop.ddd when shutting down DIAdem to make it persistent.
(6,566 Views)
Thanks for quick respond. I have solved it by changing DataStore to Computer. Users don't need to connect to server or somethig like that, and i think that the local it is blocking this types of connections.
Thanks for the advice and have a nice day.
(6,549 Views)
The Datafinder is a local index service for measurement data.
It is a local server running on the same machine given you the ability to find (full text, advanced) files using their meta data.
It is extremely helpful if you have a bunch of data.
(6,547 Views)
By the way ther error is conected to the
Windows Service "NI PSP Service Locator"
that should be up to make Datafinder work.
(6,519 Views)
Thanks for advices. Everything is fine now and Datafinder have started properly.
(6,513 Views)
