DIAdem
Harmonic Cursor with more than 5 Harmonic
I need a Harmonic Coursor with more than 5 lines.
By default it has only 5 lines for harmonic.
(4,609 Views)
Hello Aquilin,
Please have a look at the following example in the DIAdem help system:
It will lead you to the following example, which allows you to set the number of harmonic cursors:
I hope that's helpful,
     Otmar
Otmar D. Foehner
(4,597 Views)
Hi Aquilin
you can use the Setting dialog in VIEW:
(4,591 Views)
