Components
Syslog Component
Please post your questions or feedback on the Syslog Component here.
(This component will be posted within a week of the start of this thread. Until then the link above will return an error.)
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 1 of 26
(28,723 Views)
Any chance your group has already developed a new reference library for RFC 5424 that obsoleted RFC 3164:
http://en.wikipedia.org/wiki/Syslog
One thing I like about the new standard is fractional second resolution on the timestamp, where 3164 only has whole seconds.
Thanks for all your help.
Message 2 of 26
(27,794 Views)
Hello
I have used syslog in LV for Windows in applications.  I wonder if there is a syslog in LV for Linux.  I would like to use syslog collector on Linux machine for our third party partner.
any suggstion is more than welcome.
cheers
xg
Message 3 of 26
(27,311 Views)
xg,
The LabVIEW Syslog client and collector is written completely in LabVIEW source code, so it can be run on any LabVIEW platform supporting UDP including Linux. You can copy the source files from your Windows system to Linux and they should work.
I have added two more downloads to the Developer Zone document which are a VI Package (*.vip) for use with VI Package Manager and a ZIP file containing the source files. Either one of these can be used to place the files directly on a Linux machine.
authored by
Christian L, CLA
NI - Austin, TX
Message 4 of 26
(27,305 Views)
Hi, Christian
Many thanks.   is this  document       ni.com/devzone/cda/epd/p/id/5980  ?
I will have a go for that
cheers
xg
Message 5 of 26
(27,146 Views)
Hello, Christian
I  downloaded the syslog1206_source.zip, unzip and placed syslog directory under my LabVIEW 8.6/user.lib.
when I first tested the collector.vi example, it did not work. it turned out that the default port number of 514 is not working under Linux.
after I changed the default port to 6160 and also modified syslog_device.vi to have syslog port as 6160 and 6161, both collector.vi and device.vi examples work.
I now can start the collector.vi on Linux machine and run device.vi both on the Linux machine and on my windowXp Laptop.
again, many thanks
xg
Message 6 of 26
(27,135 Views)
Hello, Christian
I have an issue in using the Syslog Client application and wonder if you can suggest a way out.
I have two different applications ( LabView EXE) running on the same machine which like to send log message to the SyslogCollector ( running on another machine).  The current  syslog.device.init will only work for whichever the first running appllication,  it fails if the second application tries to call it.
is there a way to deal with this situation? or we can not run more than one appliaction on the same machine for sysLog Device.
thanks
xiaofeng
Message 7 of 26
(27,081 Views)
xiaofeng,
This will require using two different UDP port numbers on your local comuter, one for each LV EXE. Currently the Syslog API does not support setting the local UDP port number.
Until we have the chance to add this feature you can add it yourself by modifying the Syslog Devioce Init.vi and syslog_Device Function Engine.vi (Init case).
In this case there is a constant labeled 'regular syslog port'. You will want to convert this to a control and export it out through the VI terminal connector to the top level API where you can set it differently in each of your applications.
authored by
Christian L, CLA
NI - Austin, TX
Message 8 of 26
(27,077 Views)
many thanks, Christian,  I will have a go
xiaofeng
Message 9 of 26
(27,072 Views)
The VI "Syslog Device Send.vi" has an error cluster based case structure. If an error is present, nothing is done.
If there is no error and the "Message Tag" and "Message Content" string controls are empty, then it tries to read the error cluster to create the syslog message.
The upshot is that errors reported in the error cluster will cause the syslog message to not be sent, even if the intent is to send the error message in the error cluster.
Message 10 of 26
(25,738 Views)
