Certification
Car Wash for CLD - need some help with logic
I am posting not in the review thread because I have not finished the documentation part although the core functionality works somewhat.
I have a couple of questions. Please have a look at my application
1. My Slider won't go to Entry position after I move it to Exit but works when I turn on highlight execution
2. I create an array of the wash options selected and add it to a Queue. And so it gets executed sequentially. In case the buttons were pushed randomly, I will have to move back and forth which does not fit well with the application. Could you offer some help?
(3,783 Views)
Few Controls (Typedef) are from Different locations (Path referring your physical directory) make sure all the files are placed in such a way that your main VI Loads without error
(3,766 Views)
That just screams "Race Condition".  Without looking at your code, my guess is that you have parallel loops trying to update that indicator via a FGV or local variables.
(3,760 Views)
Reg Point1: I Disconnected all the type def functions but i am not able to replicate your issue, it will be goof if you can explain better.
Reg point 2 : hope you don't want to push it randomly, once its selected it has to get disabled until it completes all the cycles. using array of selected elements(Cycles) will work good for you.
(3,758 Views)
Well, it works now. I just noticed an unwanted local variable. Thanks anyway
(3,754 Views)
My bad. I did not notice it. I have changed the locations.
(3,753 Views)
Great if your job is done you can document and submit for review.
(3,747 Views)
