Certification
CLD-R sample exam question19
I doubt the answer to the question 19 which is C. There is no bd of calculation vi.
bp
(6,462 Views)
Accepted by bharathp10
You are looking at Calculation.vi.  It is using recursion.  So end the end, you have 4*3*2*1 = 24.
(6,412 Views)
Hi crossrulz,
Thanks for the feedback.
The BD is of  the calculation.vi 🙂  that was tricky.
But in that case it is mentioned as reentrant which means it should have different  instance on each recursive call right ? also its not specified if its a shared clone or not
bp
(6,408 Views)
A couple of issues with this question:
1. This is a really old way of doing recursion.  Sometime in the last 15 years (taking too long to figure when), you can just call the VI directly (don't have to use VI Server).
2. The VI will need to use Shared Clone reentrancy.
3. The example CRD-R has not been updated for a very long time.
4. The example exams are typically rejected questions.  So the actual exam is hopefully better.
(6,399 Views)
Yes it is based on 2009 LV version I think.
bp
(6,394 Views)
In the German version this question is much more difficult. The text don't contains the name of VI: "Calculation.vi".  I can not see, that here is a recursion.
(6,308 Views)
This is one part funny, two parts sad:
I would not have gotten that question right, but I would not lose any sleep over it either.
(6,223 Views)
