BreakPoint
Wire = variable..... or wire != variable...
@Ray.R wrote:
You're not Sheldon, are you??
I surely hope i'm more socially competent ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 31
(12,601 Views)
@Yamaeda wrote:
@altenbach wrote:
But does the mere act of reading the value of the wire potentially change it's value? 😄
Actually it does, since i found a bug in 2010 beta whereas a calculation would fail unless i had it wired to an indicator ...
/Y
LV will skip code that is not used down stream since as far back as 5.0 to my knowlege.
THe has never been a one to one relationship between wires and storage allocation. That is what made Wack-a-mole so much fun. We express out idea in the diagrms and LV inteprets what we say but rarely do we direct variables. LV decides.
Q SRs in AEs?
Variables?
Ben
Message 12 of 31
(12,588 Views)
That clearly states it.  There is no such thing as a variable in LabVIEW..
Message 13 of 31
(12,572 Views)
Just throwing in some points that pop out of my brain:
1. We must take into account the knownledge and aims of our discussion partners. If they come from a background of text-based programming languages, they ask for 'the variable' and we are right to tell them it's 'the wire'. As normal LV-users they don't really care about memory-allocation and other compiler issues. I don't think they would benefit if we would use a more scientific precise explanation such as 'the wire is the construct to be used equivalent to a variable'. Better KISS (Keep it short & simple).
2. If they are clever (in terms of math/CS), they will ask how to make a loop invariant. So we present them the shift-register. Well, that's closer to what I would think about as 'variable', 'cause the value changes (in the LV-world).
3. I just checked wikipedia on variable:
In computer programming, a variable is a symbolic name given to some known or unknown quantity or information, for the purpose of allowing the name to be used independently of the information it represents
My interpretation: So a very important point on variables is to make it human-readable like 'i' or 'pressure' and not #00123ABC. A wire doese make that identification.
Felix
Message 14 of 31
(12,508 Views)
I think
Controls is a data container[Controls are similar to the data containerbut the controls is not variable.
Wire equal to the assignment (=)
Control data is passed to the indicator, through the line, the equivalent of an assignment
LV have variables, local variables, global variables, shared variables
My English is poor, the expression is not clear.
" 一天到晚游泳的鱼"
labview@263.net
我的个人网站:LabVIEW——北方客栈 http://www.labview365.com
欢迎加入《LabVIEW编程思想》组——http://decibel.ni.com/content/groups/thinking-in-labview
Message 15 of 31
(12,484 Views)
I think
Controls is a data container[Controls are similar to the data container]but the controls is not variable.
Wire equal to the assignment, Such as "="
Controls data is passed to the indicator, through the wire, the equivalent of an assignment
LV has variables. Such as local variables,global variables, shared variables
" 一天到晚游泳的鱼"
labview@263.net
Message 16 of 31
(12,388 Views)
@jwdz wrote:
I think
Controls and indicators should not be viewed as equivalent to variables. When they are you end up with code that has tons of controls and indicators whose only purpose is to hold a value. Overuse and incorrect use of local/global variables also lead to race conditions since you are breaking dataflow simply to access data on the block diagram. (Shared variables are a little different and I generally avoid using them. I prefer to define an actual API between processes for passing data between them.)
Controls and indicators should be only viewed as user interface elements or inputs and outputs from a subVI.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 17 of 31
(12,367 Views)
I actually like 'jwdz's view. While it might be completely wrong concerning the LV compiler, from the user perspective it's very clear. You 'assign' one output of a SubVI/function as an input to another one (or more). This idea emphasises that no other process/operation can alter the value of that 'variable'. That's much closer to the 'signal' concept of LV/dataflow than the 'variable'.
But then again, the 'variables' (include controls and probes) are buffered test points from an EE (electrical engineer) point of view.
Hope you ('jwdz') can follow my thoughts, despite language barriers. Privately, may I ask you where you come from/are located (mainland zonghua?)?
Felix
Message 18 of 31
(12,356 Views)
F. Schubert 已写:
Felix
I am come from People's Republic of China (Harbin),mainland 。
" 一天到晚游泳的鱼"
labview@263.net
Message 19 of 31
(12,347 Views)
True that I do not understand the LV compiler.
Controls and indicators used to store data, but they are not C language variables.
Controls and indicators is the data container (shell)。
Wires equal to the assignment, Such as "=",Similar to the an equal sign。
Wires are not a variables.
Local variables is from the controls(data) and indicators(data).
Global variables is also from the controls(data) and indicators(data)
" 一天到晚游泳的鱼"
labview@263.net
Message 20 of 31
(12,341 Views)
