BreakPoint
Why some people say Local Variables are bad...
Maybe simply change their name so that people not confuse them with text-based "Local" variables.
Ray, I very, very agree with this. When you come from a text based language and you look for the variables (which is really clever, look in some manual for variables when you are faced with LabVIEW the first time), you get presented locals and globals AND NOT THE WIRE! It's not the poor guys that write such bad code we should blame, it's that 'we' name these 'control update nodes' wrongly after a basic programming concept.
Someone should get a rename for them on the IE. Ray?
Felix
Message 221 of 396
(8,477 Views)
@Ray.R wrote:
I was thinking about that this morning.
Then you would have people not wiring the error-in/out...
Humm..... in essence, they are similar, in that it is local to the VI or function...  But it is more of a copied instance of the data than the variable itself..
If it wasn't for the dataflow and the parallelism in which LabVIEW executes, then they would be fine...
I don't know what the solution is... And I hate seeing the communitu divided by a Local Variable..  😞
I second the rename option, it would cut most of the problems in the bud.
Just thought I'd expand on a point mentioned which I'd never actually considered.
Shane
Message 222 of 396
(8,472 Views)
@Ben wrote:
You would have to re-invent the local such that it was protected by a semaphore so we could do a "Locked-Read" proprty taht would return the value along with a semaphore locking reads of the local until that thread wrote back to the local and released the semaphore.
So whole idea;
Only one local write allowed.
All others must be a protected write.
Seems silly,
Ben
I meant only to be able to determine the time of readint / writing the local.  I can't comment on the rest.  I have too little experience with Locals....
Message 223 of 396
(8,472 Views)
Totally agree with you both.
We could look at tbob's idea of a WORM Global..
We could adopt the same WORM for Locals.  And then, no more problems..  Heck, I'd probably end up using Locals (or whatever they are named).
It probably upsets the newbies to LabVIEW that we're telling them that Local Variables are not what they think they are when comparing to a text-based language.
They probably think we are completely insane when we mention that the wire is the variable..  Wouldn't you?  😉    "we're insane, but that besides the point"
But what name could we replace "Local Variables" with?
Message 224 of 396
(8,473 Views)
@Intaris wrote:
So whole idea;
Seems silly,
Ben
I like the idea of setting or having to set a write permission before being able to write again, kind of like a semaphore, but not 100% a semaphore..  It would be a lock triggered by a write and would require a property node or special function to allow writing to it again..  However, that would not prevent someone from always resetting the write operation all over the block diagram...
We have to think about this one so that it is either fool-proof or crazy enough that someone would not want to abuse the use of the Local.
I kinda see the code in my mind...  Maybe I should post an idea of what's brewing..
Message 225 of 396
(8,468 Views)
Unfortunately, sometimes people inherit really bad code. Attached is just a small sample. And I DO mean small sample.
Message 226 of 396
(8,379 Views)
I think of Locals as mirrors, which can lie. How about "Value Mirror", or "Local Mirror"?
Richard
Message 227 of 396
(8,349 Views)
Original source: The worst LabVIEW documentation of all time: this article shows two uninhibited loops (100% CPU) and a race condition, but does not warn against the practices. Below is a sample from the documentation:
24318iC9569A13BF28BF6F
Message 228 of 396
(8,284 Views)
Wow!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 229 of 396
(8,257 Views)
Richard
Message 230 of 396
(8,223 Views)
