Philbot
Create Local Varaibles with the correct read/write attribute.
Status: Declined
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
When I right-click a Control or Indicator on the FP or BD, and select "Create / Local Variable" I always get a Writable Local Variable. This makes senser for an Indicator, but not a Control. It seems to me that if I create a Local Variable from a Control, it should default to being Readable, so I can wire it immedatley (rather than forcing me to "Change to Read" every time). Phil.
Get a life? This IS my life!
10 Comments
Dennis_Knutson
Knight of NI
I disagree. When I create a local for a control, I typically want to write to it. If I want to read from the control, I read it directly - not from a local.
Philbot
If I could read the Control locally I would... but the reason I'm using a local variable is because I want to read the control's value from a sepparate loop/thread. That's what I was taught was their main function for existing... inter-thread communication. eg: using one stop button to halt two loops. You are using a local to write to a control to enable you to override the normal data flow model. OK, I see the value of this... but I'm surprised LV considers it to be the default usage for a local derived from a control.
Dennis_Knutson
Knight of NI
Well, I remember when locals were introduced with the announcement that you can finally write to a control and read from an indicator. Since I seldom stop parallel loops with a global but constantly need to set controls to some value from ini files, I object to a blanket change of the existing behvior
Perhaps a user selectable option to change what type is created would be more appropriate.
TCPlomp
Trusted Enthusiast
What about an easier way to change the direction?
Perhaps ctrl-click on a local variable would alter the direction.
Ton
My LabVIEW Ideas
Intaris
Proven Zealot
Or how about it automagically choosing read or write when actively wired to (but not when wires attached to it change their status - this would be a nightmare)
Philbot
"I remember when locals were introduced with the announcement that you can finally write to a control and read from an indicator". Interesting. Allthough I've got 35 years of programming experience I've only been using LabVIEW for 2 years, so my viewpoint is skewed by recent support material. All of the training examples I have seen, only use locals for intercommunication, rahter than overriding normal FP control usage: eg: http://zone.ni.com/reference/en-XX/help/lv/71/lvhelp/Writing_to_One_Front_Panel/ Thanks for pointing out this other (now obvious) application. Phil.
JackDunaway
Trusted Enthusiast
Philbot, thanks for pointing out that article - I have nominated that "Help" Article into the Local Variable Hall of Fame. It demonstrates the top two most common mistakes in LabVIEW - a race condition and an uninhibited loop (which causes 100% CPU utilization). But instead of academically stating "don't do this!" it misleads the reader by failing to identify either programming faux pas.
devicx
I think Ton's suggestion works well, as a general-purpose solution.
My only addition to this idea is this (more of a reminder, really, as I'm certain it has been mentioned elsewhere):
Ctrl+click is an improvement, but really, this could be done during placement, as almost always, I know whether or not I'm going to switch to a "write local" then and there. (That is, I don't come back to the local weeks later and realize it should be a write instead of a read. Your workflow might, of course, differ.)
By way of example, the status quo, Ton's suggestion, and my suggestion follow:
Currently, I have to place the local, rmb over it, and select a context-menu option (requires three actions).
Placement followed by "ctrl+click" requires two actions.
Ctrl+place is a single action.
Of course, Ton's suggestion could be used to apply to a large number of locals at once, but that's another usage case.
In any case, Kudos for bringing this up. This has been a source of irritation, albeit a minor one, for many moons.
sdubrul
Kudos for easy changing the read/write behavior of a global var.
I would propsee hitting the key R or W to change it.
This would work during placement of the global or as well as when it's selected.
Darren
Proven Zealot
Status changed to: Declined
