BreakPoint
Starware - A new concept ?
Stradis wrote: My question is, how the heck do you paste the code directly into the post.
This is a limitation of the forum software. In principle, it should be doable to arrange things that you could point to a local image file and then upload and embedding would happen behind the scenes automatically. So far this is not implemented. Sometimes people try and you see links such as file ://c:\....abc.gif which are obviously broken for the rest of us.
The image URL can be anywhere that allows external linking. Instead of attaching the image to the post and then inserting the resulting URL, you can also upload your image to any image hosting site (photobucket, imageshack, etc.) or private web server and link from there.
Message 51 of 121
(15,996 Views)
And I reintroduced that bug in my latest test version Smiley Mad
Ton
My LabVIEW Ideas
Message 52 of 121
(15,948 Views)
  Want to spice up your posts ?
          Try this !
Choose an emoticon, click, and the corresponding file location will be copied to the clipboard, ready to be pasted in your reply.
 Cool isn't it ?
For optimal use, you should configure the vi to let it run when opened, and drop it in the LabVIEW project folder.
Enjoy, comment, suggest many improvements... and give a lot of stars (five only please...)
Message Edité par chilly charly le 11-02-2007 09:16 PM
Chilly Charly    (aka CC)
Message 53 of 121
(15,748 Views)
Testing, un deux trois....
C'est magnifique!!!!!
- tbob
Inventor of the WORM Global
Message 54 of 121
(15,732 Views)
I gatta check it out... I always ask for more icons!!
Thanks CC!!
Message 55 of 121
(15,719 Views)
Message 56 of 121
(15,708 Views)
There is at least one bug that should be corrected : a duplicate adress !
Modify the adress block constant as shown below, otherwise you'll get twice the "eek" icon.
And thanks to Ben and tBob as early adopters !
Message Edité par chilly charly le 11-03-2007 08:18 PM
Message 57 of 121
(15,690 Views)
CC,
THis is a very creative demo.
You had me saying "How'd he do that?"
All of those gifs take a lot of CPU.
Thanks CC!
Ben
Message 58 of 121
(15,686 Views)
By adding a defer delay .5 sec undefer in a timeout case (set for 30 msec) you have a unique VI !
It actually takes less cpu when its NOT running than when it does.
Ben
Message 59 of 121
(15,688 Views)
Well, I must
I was working on that problem, but with a different approach, and no success. Let me  you.
Message 60 of 121
(15,687 Views)
