BreakPoint
Rube Goldberg Code
Sorry all is my fault actualy. I was 100% sure i saw the Array Subset function. Smiley Surprised
Message Edited by t06afre on 12-18-2008 05:38 PM
Message Edited by t06afre on 12-18-2008 05:39 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 401 of 2,635
(12,259 Views)
Yet another example of using Select instead of Boolean operations:
From here.
Message 402 of 2,635
(12,183 Views)
In fairness, the lower selector (F) of the upper select function is not guaranteed to be false, at least not from the picture provided.
We also can't see what the ? is wired to in the lower select function.....
So they may at least have proper functionality.  True, it could be done with an OR statement, but I personally don't see the problem with the Select method.
Shane.
Message Edited by Intaris on 12-27-2008 06:34 PM
Message 403 of 2,635
(12,176 Views)
The link I provided has the original code. The use of the 2 Select functions can be done more succinctly with an OR and an AND gate.
Message 404 of 2,635
(12,147 Views)
Small RG code dealing with converting a number to a 24-bit small-endian data string. We can do a bunch of array gymnastics, or just use the Flatten To String function:
From here.
Message 405 of 2,635
(11,993 Views)
Any reason we don't reverse the string in the lower section?
Ton
My LabVIEW Ideas
Message 406 of 2,635
(11,997 Views)
reverse the string? I'm not sure what you're referring to.
Message 407 of 2,635
(11,993 Views)
Sorry I missed that the upper part was the clean part.
In the lower part there is a superb 'Node Equivalent' section:
Ton
Message Edited by TonP on 01-26-2009 09:52 PM
My LabVIEW Ideas
Message 408 of 2,635
(11,934 Views)
Good catch Ton,
As you noticed, the bottom one was the RG.  The top one was cleaned.  Both solutions are good.  I don't know if one would actually be better than the other..  Comments anyone (on preference)?
R
Message 409 of 2,635
(11,796 Views)
Advanced PID fromthis thread
Ben
Message 410 of 2,635
(11,762 Views)
