BreakPoint
Rube Goldberg Code
@VinnyAstro wrote:
Yet the OP should know about autoindexing, since a FOR loop automatically creates one when you input an array... So that means that they've disabled it on purpose 🤔
Or they started with a While loop and r-clicked and changed it to For. 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 2571 of 2,635
(2,196 Views)
In a nutshell, we basically have a 2D boolean array to be turned into a single boolean according to some rules.
I have that nagging feeling that this could be simplified somewhat. 😄 (seen here)
Message 2572 of 2,635
(2,048 Views)
shiftregisters and one OR 🙂   just keep the boolean information (edit: first SR init to false 😉 )
or concentrate the arrays followed by OR-array , boolean array to number is max 64 bit  (more will be truncated, so I assume each loop run 64 times max). Who cares for 16k memory nowadays 😄
Greetings from Germany
Henrik
LV since v3.1
Message 2573 of 2,635
(2,010 Views)
Put the indexing on Last Value, and make it conditional:
Message 2574 of 2,635
(1,984 Views)
@Broken_Arrow wrote:
Saw this today:
If an outer while loop contains an event and another inner while loop and  both the event and inner while loop are separate, then is there any possibilty that the execution comes out of the inner while loop when the event occurs and after executing the event it comes back to the inner while loop where it was previously executing,
just for the sake of curiosity
Spoiler
Message 2575 of 2,635
(1,885 Views)
Saw this today:
Spoiler
Did you turn off the "Lock Front Panel Until Event Is Handled" for both of those controls?  It looks like an extra button press is locking the front panel since the Event Structure is not being handled due to the extra loop inside of the loop.
Message 2576 of 2,635
(1,908 Views)
no, I didn't uncheck Lock Panel, which is checked by default (scenario 1)
Spoiler
when unchecking that flag AND saving the .vi (scenario 2)
Message 2577 of 2,635
(1,898 Views)
Why aren't the buttons latch action?
Why is the an timeout case that can never happen?
Why is the inner loop greedy?
Why is there a sequence structure?
Message 2578 of 2,635
(1,871 Views)
- because you can't use local variabels with that mechanical action
- because, I don't want any timeout effects, can it be removed?
- because it was suggested by the OP
- because I use local variabels, and want them to be executed first
Message 2579 of 2,635
(1,857 Views)
back  to topic 😛
Message 2580 of 2,635
(1,855 Views)
