BreakPoint
Rube Goldberg Code
Ways to cast a two byte string to a number.
(the original seen here)
Message 2321 of 2,635
(5,224 Views)
Careful!
The Unflatten From String solution is only the same if there are two (or more) characters in the string!
Message 2322 of 2,635
(5,210 Views)
wiebe@CARYA wrote:
Careful!
Yes, but here he is reading exactly 2 bytes from the network, so the size is guaranteed. 😄
Message 2323 of 2,635
(5,206 Views)
Converting three bytes into a floating point value (seen here).
I have the nagging feeling that we don't need anything green and much less orange.
Message 2324 of 2,635
(5,141 Views)
To a text programmer, this formula node probably looks very reasonable. I have the gut feeling that there are simpler alternatives. 😄 (seen here)
Message 2325 of 2,635
(5,004 Views)
Sometimes the Rube Goldberg is not in the code, but in the external wiring. (seen here)
Question: "Please share ... connection diagram of how everything is wired up"
Answer:  The encoder is connected to Counter 0 while the servo connections are made to the Counter 1. The Encoder has 5 cables and they go into pins 96 (+5V), 86 (DGND), 81 (channel A), 85 (channel B) and 83 (Z index). Servo has 3 cables and they go into pins 96 (+5V), 94 (DGND) and 91 (signal).
I already see the sparks fly!
Message 2326 of 2,635
(4,969 Views)
Jesus christ, that cable is completely shredded. How it didn't blow up yet is a real mystery.
Message 2327 of 2,635
(4,932 Views)
Lots of lessons to be learned here (please pitch in 😋).
Some highlights (RB, Bugs, and other madness):
Message 2328 of 2,635
(4,851 Views)
Can you explain the up to three values for each time point? Are they related?
Message 2329 of 2,635
(4,800 Views)
I think there's time, and then 1, 2 or 3 (maybe more?) values. The graphs shows the 1, 2 or 3 values as a function of time. So I think those values are positions, and s(he)'s trying to correlate the positions to 1, 2 or 3 objects that move over time, in one dimension.
But that is my interpretation.
I do see a strong coherence between bad solutions and bad explanations of the problem. 🙄
Message 2330 of 2,635
(4,761 Views)
