BreakPoint
Rube Goldberg Code
I went through it so quickly that I didn't even notice that you had fixed my original.  Does it help my case to say that that code is almost three years old?  No, I guess not...
Jim
Message 931 of 2,635
(12,068 Views)
Did you say the code was written by a thre year old?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 932 of 2,635
(12,059 Views)
Hmmm.. I realized the index array can be replaced with a while loop.
I wonder which is faster This has 10 nodes compared to the 9 in the first "fix" and 11 in original.
"Should be" isn't "Is" -Jay
Message 933 of 2,635
(12,053 Views)
Ouch...
Jim
Message 934 of 2,635
(12,049 Views)
Ok, I'll admit I haven't actually opened and looked at the case structure, but if i remember correctly from my bench marking tests Jeff, while Jim's code may be "Rube'd" it'll run faster than your's. The reason being that a string into a case structure always needs a default case, and LabVIEW seems to take more time to run this than a boolean check and case structure. It seems to check how many cases it has, if the string matches an existing case and then if not, it runs the default case. Jim's code just does a simple boolean check and on long strings, or where you are only looking to match one string (a boolean check). Jim's technique is more effiecient in time and memory in LabVIEW - certainly before LabVIEW 2010.
- Not sure if that is a Rube Jeff! Smiley Wink
Please feel free to correct me anyone who has actually bother testing this or can remember better!!
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 935 of 2,635
(12,025 Views)
What is the benefit of replacing the Index Array with a While Loop?
I would have used the index array myself.  Is it indeed a Rube?  Since it is not really adding complexity.
-curious-
Message 936 of 2,635
(11,998 Views)
OK the challange involved Jim fearing seeing his latest snippet in the thread.  So I went to his images - I would have posted it in reply WITHOUT regard to any R-G constructs found.  Smiley Very Happy BONUS a compare to constant feeding a case selector WAS found- It may be faster to do so in this instance.  If so Jim RG'd it for optomization and I'll take the knowledge and apply itSmiley Wink
Message 937 of 2,635
(11,990 Views)
Interesting way to see if a boolean array as changed (top of image).
It is also not very clear why we need to read the local variable into the output if it is the same as the input array (TRUE case, not shown)
(Also substituting a local variable for a shift register as suggested is probably not such a great idea!)
(seen here)
Message 938 of 2,635
(11,959 Views)
(seen here)
Because the output and input are not the same until after the vi is executed. I thought about using a feed back node. Two differnt ways to do the same thing.
Tim
GHSP
Message 939 of 2,635
(11,944 Views)
In your TRUE case, they are the same so there is no need to wire the 1D array across the case structure at all, right?
Message 940 of 2,635
(11,938 Views)
