BreakPoint
Rube Goldberg Code
And Jack wins a prize for code obfuscation
Maybe I'll wait for official support after all.... !Smiley Surprised
Message 661 of 2,639
(12,492 Views)
I am going to link to an interesting VI here.
It isn't so much a Rube Goldberg, though there are a few Rube constructions like building an array of string constants rather than just creating a constant that is already a string array.  The code is actually neatly laid out, but really just has a lot of wrong things going on it.  It could also be a good nomination for the Local Variable thread.  It uses stacked sequences.  It uses a weird intermingling of single sequence frames, single iteration while loops, multiple iteration while loops, bits of data like a boolean whose only purpose is to link stuff together to have it operate in sequence, even if the two things that it is linking could be a single 2-frame flat sequence (or going the bad route of a stacked sequence which has been done numerous times.)
But just to give a taste, here is the beginning of the very linear program, and the comment that I thought was funny and fitting about the "penalty box".  (Actually, the whole program looks like a linear sequence of penalty boxes.)
Message Edited by Ravens Fan on 04-07-2010 10:42 PM
Message 662 of 2,639
(12,451 Views)
Wheew!
That looks like it was developed by an "inside-the-box" thinker!
"Should be" isn't "Is" -Jay
Message 663 of 2,639
(12,404 Views)
Here is one of my own dandies from here, where nathand set me straight.  All of this
gets replaced by this
At least I recognized it as Rube when I posted for help...
Tim Elsey
Certified LabVIEW Architect
Message 664 of 2,639
(12,391 Views)
Hey, have you been looking at my project from work? It looks _exactly_ like that with sequentitis and penalty boxes!
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 665 of 2,639
(12,357 Views)
Could I just say, rather than make a 300 shift-register solution to http://forums.ni.com/ni/board/message?board.id=170&message.id=490052#M490052 to get a mention. I'd rather not be evil in the process.
Message 666 of 2,639
(12,297 Views)
found here
Message Edited by Broken Arrow on 04-14-2010 04:19 PM
Richard
Message 667 of 2,639
(12,230 Views)
Broken Arrow wrote:
 I was just going to post that. A WEQ!
You did not show the entire WEQ code. See what the output of the case structure is!
Message Edited by altenbach on 04-14-2010 02:39 PM
Message 668 of 2,639
(12,223 Views)
Yeah Smiley Happy but I've seen that before. The ol' True if True and False it False statement.
Richard
Message 669 of 2,639
(12,213 Views)
Sometimes it is difficult to understand why certain code is the way it is.
In this example, arrays are built for a lifetime of a few clock cycles, just to break them down again in the next primitive.
Look at the first row of the built 2D array, it is never even used! Why???
Message Edited by altenbach on 04-17-2010 09:51 AM
Message 670 of 2,639
(12,132 Views)
