BreakPoint
Regular Expressions Board
Beat me to it!
The alt text for the comic also has an amusing regex.
CLA
Message 131 of 150
(7,475 Views)
this one?
Spoiler
/bu|[rn]t|[coy]e|[mtg]a|j|iso|n[hl]|[ae]d|lev|sh|[lnd]i|[po]…last names of elected US presidents but not their opponents.
Greetings from Germany
Henrik
LV since v3.1
Message 132 of 150
(7,454 Views)
There's a nice inspection of the regexes and their efficiency from that comic here. Turns out they can be whittled down further.
Nice if you like that sort of thing, I mean!
CLA
Message 133 of 150
(7,401 Views)
How to improve the following regex:
DI([0-9]+)([\s]+=[\s]+)([\S]+)
I'm sure something better can be done for :  ([\s]+=[\s]+)
which is to remove the \s=\s  or \s\s\s=\s\s\s or any amount of white spaces surrounding the equal sign.  I guess, there might be a situation where there are no spaces, but unlikely..
Thanks..
Message 134 of 150
(7,339 Views)
Brackets are for alternatives, not needed when you have a single alternative.  [\s]+ = \s+.  Personally I would allow for no spaces unless your grammar explicitly forbids it.
As to improvements, beyond the bracket removal I would not change much.  Shaving a few characters here and there will not affect compile time or search time noticably so I would leave it written in the way you understand.
Message 135 of 150
(7,321 Views)
Thanks Darin!
Message 136 of 150
(7,312 Views)
It looks like you might be trying to match a key value pair, where the middle submatch is "trash". You can make that a non-capturing group, and allow optional spaces around the "equals":
DI([0-9]+)(?:\s*=\s*)([\S]+)
Capture the DI number in the first submatch, and the value as the second submatch (ignoring the equals sign and any arbitrary amount of whitespace between the two). Note that \s captures more than just spaces, however -- it captures all whitespace (depending on how you configure Multiline). With a little more context, we could add some anchors to better constrain the match, ensuring it doesn't, for instance, choke on key/value pairs with an empty value.
Message 137 of 150
(7,303 Views)
Thanks Jack,
Here's a couple of examples of lines this regex will be dealing with:
DI000 = BPtxMute
DI001 = BPsystem-Failed
Nothing fancy..
I like to learn how to optimize regex code, hence my posts.
Message 138 of 150
(7,292 Views)
How do I find the exact match for a defined pattern? For example:
I need to find $a_LIFT as an exact match. My input strings are
1. if $a_LIFT eq 20
2. if $a_LIFT_TEST eq 0
when using regular expression as \$a_LIFT it pick both #1 and #2 in the search like a greedy match.
Any pattern that is input as regular expression needs to be matched exactly in the input string and disregard any other matches.
Thanks.
CLD
Message 139 of 150
(7,158 Views)
1. if $a_LIFT eq 20
Thanks.
The confusion here might be what "exact match" means, from your perspective compared to the regex engine's perspective. 🙂
\$a_LIFT as a regex indeed finds an exact match for both lines, but it's likely that your desired semantic is closer to ...
\s|\A\K\$a_LIFT(?=\s|\z)
... meaning, "let's define 'exact match' to mean \$a_LIFT that is preceded by either an ignored whitespace character or the beginning of the string, followed by a whitespace character or the end of the string which we'll also ignore." (Consider a lookbehind instead of the \K keep operator if the lookbehind is fixed-width instead of variable width... for example, have a go with (?<=\s)\$a_LIFT(?=\s) if you don't need the begining/end of line anchors in your application)
Message 140 of 150
(7,148 Views)
