BreakPoint
Monthly Bugs, November 2007
This is the continuation of the October bug thread.
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread
Message 1 of 18
(10,290 Views)
Apparently, it was once possible (7.1) to blink individual cells of listboxes. The same code now blinks the entire listbox. Bug? Feature?
Message 2 of 18
(10,290 Views)
A call to the "Value (Signalling)" property using a non-strict table reference causes error 1058 ("Specified property not found.") in LabVIEW 8 and greater.
CAR# 4F1A1BF2
http://forums.ni.com/ni/board/message?board.id=170&message.id=281933
Jaegen
Message 3 of 18
(10,258 Views)
There seems to be a weird issue where case structures don't allow the full integer range of the integer data type wired to the selector.
Message 5 of 18
(10,174 Views)
Would you consider this TDMS behaviour a bug?
Message 6 of 18
(10,155 Views)
Sometimes, the customized plot legend from a waveform graph, chart, or XP graph is corrupted when insteretd the control into 8.5.
Please look at the first problem listed in this thread.  I don't think the 2 problems are related any more.
Message Edited by Matthew Kelton on 11-14-2007 11:10 AM
Message 8 of 18
(10,071 Views)
You cannot customize the Plot Legend of the XY Graph, Waveform Chart, or Waveform Graph in 8.5.
Please see the second issue (and most of the rest of the thread) in this thread.  I do not believe the 2 issues are related.
Message Edited by Matthew Kelton on 11-14-2007 11:11 AM
Message 9 of 18
(10,071 Views)
The "edit items" dialog of a DBL ring control does not accept data at the full resolution of the data type.
Message 10 of 18
(10,044 Views)
