BreakPoint
Fatal Internal Error: "image.cpp", line 13192 when trying to insert a cursor to graph
As the title says..
I have an existing graphs which has 3 cursors.  Works great.  Been running tests for a while.
I need to add one more cursor to the existing graphs.  As soon as I add a new cursor and set it's properties, I get a nasty error message and without warning LV8.2 simply closes itself.  Tried it 3 times, same result.
Shut down the PC, went for a coffee, rebooted the PC.  Opened the LV project, opened the VI.  Immediately went to the graph properties to add the new cursor by doing the following steps:
Right click graph indicator icon on block diagram.
Select Properties.
Click on cursor tab.
Click on Add
Select Cursor 2 (3rd one, newly created)
Change color
Select cursor as a line
Remove checkmark for "show cursor"
Click OK
I need to do this to 3 other graphs, same steps.  And as soon as I get to the step before clicking OK, I get the error message.
I now managed to get one done, and immediately saving.  But I've had this problem before when creating the first two cursors.
Is it a bug?  Anyone else seen this?  Using LV8.2.
And the message is right about LOOSING ALL unsaved work!!!!  😠
RayR
Message Edited by JoeLabView on 12-10-2007 11:39 AM
(6,829 Views)
Additional notes:
Tried creating a new one on the second graph.
As soon as I clicked on the color, it crashed!
At least the error explanation is clear, now I can try to solve it 😉   LOL!!...  There's a bad image out there 😄
.\manager\image.cpp(13192) : DAbort: bad image in ValidateImage
$Id: //labview/branches/Europa/dev/source/manager/image.cpp#47 $
0x007A81E8 - LabVIEW <unknown> + 0
0x007A7BDB - LabVIEW <unknown> + 0
0x00829D74 - LabVIEW <unknown> + 0
0x008546CD - LabVIEW <unknown> + 0
0x00C054E6 - LabVIEW <unknown> + 0
0x0081B9C8 - LabVIEW <unknown> + 0
0x0081EB9A - LabVIEW <unknown> + 0
0x0084D9D4 - LabVIEW <unknown> + 0
0x00854663 - LabVIEW <unknown> + 0
0x0085F7A1 - LabVIEW <unknown> + 0
0x00BBACDD - LabVIEW <unknown> + 0
0x00C06A2F - LabVIEW <unknown> + 0
0x0085AA46 - LabVIEW <unknown> + 0
All sarcasm aside, anyone has a clue at what causes this? 😮
(6,826 Views)
More additional notes:
I observed the title bar after making changes to the properties.  (Yes, finally, after a # of reboots, it's done)..
I noticed that 3 out of 4 times, while changing the properties of the graphs to include the cursor, and saving after each & every step, that there were no stars appearing on the title bar to indicate "unsaved changes".  Saving was also slower than usual.  I suspect, the program never got to placing the star before saving occurred.  However, I am noting everything.
AFter creating the cursors, saving is normal, and the program runs well..
- strange -
(6,823 Views)
Ray i cant help you but it seems you mistaken on the thread. maybe send a link post from the LV forum so NI people will watch it.
... And here's where I keep assorted lengths of wires...
(6,798 Views)
Did I post this in Breakpoint??  It wasn't my intention..  😮
I did the search in the LV forum..  Didn't find anything in the search so I posted the question.  Since I was in the LV forum, I never thought it would post elsewhere, such as in Breakpoint.
Wow..  Thanks for pointing that out.
But I still don't get how it got here..  Maybe that explains why we see so many people posting questions in the wrong forum.
I will start a thread in the appropriate forum and point to this one.  I'll also mention it in the feedback thread.
Thanks!
RayR
(6,783 Views)
