BreakPoint
Monthly Bugs (November 2006)
This is the continuation of the October Bugs Thread
Rules:
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 27
(10,720 Views)
Apparent re-occurrence of LabVIEW Floating Window problem within TestStand.
http://forums.ni.com/ni/board/message?board.id=330&message.id=13149
Message 2 of 27
(10,687 Views)
Can't Async VISA Lock GPIB class VISA references:
CAR #430BLPZL
LabVIEW ChampionLabVIEW Channel Wires
Message 3 of 27
(10,660 Views)
Editing an LLB leaves a temporary file around
http://forums.ni.com/ni/board/message?board.id=170&message.id=214157
Message 4 of 27
(10,632 Views)
LV Metadata importer from the TigerTools interferes with saving LLBs.
http://forums.ni.com/ni/board/message?board.id=170&message.id=213818
Fixed MD importers is available, but needs to be repackaged
Also Metadata Importer is incorrectly installed in the /System/Library folder instead of /Library folder.
Message 5 of 27
(10,633 Views)
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=213981&jump=true
Aristos Queue ID's ab ug in the way the "Syncronous" setting interacts with the "Erase First" setting for a picture control.
CAR# =  (# 43699OJ1)
Ben
Message 6 of 27
(10,625 Views)
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=214212&jump=true
Allison reports CAR# 3R1F8KRJ
I am not sure what the bug is, Smiley Surprised  but it does have a CAR.
Ben
Message 7 of 27
(10,618 Views)
Hierarchy screen forgets settings!
In previous version of LV you set it once and forget it. Now you have to set it each time you open the hierarchy screen.
I concider this an "ease of use" bug.
See this thread.
http://forums.ni.com/ni/board/message?board.id=170&message.id=214276&a#M214276
Ben
Message 8 of 27
(10,606 Views)
Mac OS X installer (LV 8.20, VISA or NI-DAQmx base) messes up folder permissions causing possible security problem.
http://forums.ni.com/ni/board/message?board.id=170&message.id=214293
Message 9 of 27
(10,602 Views)
Jeff Peters of LV R&D indicated that the up/down arrows on an enum can be misleading.
http://forums.ni.com/ni/board/message?board.id=170&message.id=214718&jump=true
Not sure if this is a bug but it can be confusing.
Temporary work-around is to customize control and swpa up/down button postisions and then swap their images.
Ben
Message 10 of 27
(10,566 Views)
