BreakPoint
Monthly Bugs, June 2008
It is Time again for the June Bugs!! 😄 Let's retire the May Bug List and start a new thread.
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message Edited by altenbach on 06-01-2008 12:57 AM
Message 1 of 22
(10,640 Views)
hi there
here's one regarding differing barcode scanner inputs between VI and EXE version:
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=5564&jump=true
(i posted it in the wrong board)
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 22
(10,595 Views)
Anoying bug with LV switching to the FP when trying to do stuff in the BD, see here, CAR to follow.
Ben
Message 3 of 22
(10,587 Views)
See here.
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 22
(10,570 Views)
Placing a Rich Text Box on a Front Panel causes a warning message (Systems.Windows.Forms loaded from different location) when opening the VI.
http://forums.ni.com/ni/board/message?board.id=170&message.id=330901
Message 5 of 22
(10,502 Views)
hi there
Here's one where a refnum steels RETURN keys: http://forums.ni.com/ni/board/message?board.id=170&thread.id=330980&jump=true
Best regards
chris
Message 6 of 22
(10,489 Views)
Bug fixed in LV8.5.1
Message 7 of 22
(10,474 Views)
See here on LAVA.
Ben
Message 9 of 22
(10,412 Views)
I had a problem recently where a program would randomly hang for several seconds. When the program would hang, my DAQ buffers would overflow and cause a shutdown of my DAQ loop. Over the course of troubleshooting, I found that opening the right-click menu on the Windows taskbar tab of a VI would cause that VI to freeze. The background processing would still be running, but the front panel would freeze. The CPU usage would also increase to 50% on dual core or hyperthreaded CPUs and 100% on single core/non-hyperthreaded CPUs. This would happen even if the application was compiled and just using the run-time engine. Through further investigation, I found that this did not happen on LabVIEW 8.20, but it would happen on all later versions. The version my software was running on was 8.5, so I downgraded to 8.20 and the problem has gone away.
Application pauses for up to 4 seconds at random places in processing loop
Message 10 of 22
(10,352 Views)
