BreakPoint
Monthly Bugs (February 2006)
Here is a FusterCluck for all you state machine fans out there:
- tbob
Inventor of the WORM Global
Message 11 of 21
(7,509 Views)
Don't know if this is a bug or demotion.  PDARocker Classic control on LV8 PocketPC does not display the boolean text when running.  In LV7.1 the boolean text was there.Smiley Indifferent
Message 12 of 21
(7,514 Views)
In the thread below;
http://forums.ni.com/ni/board/message?board.id=170&message.id=167227
we see that in LV 8 the "Tools»Convert Build Script" function reports the user has aborted the operation when in fact an attempt was made to save a write protected VI. Simple work-around, write-enable all VI's associated with a build script!
Ben
Message 13 of 21
(7,474 Views)
When does "Bring to Center" not actually bring the cursor to the center?  When the scale is != 1.0 in LV 8.
http://forums.ni.com/ni/board/message?board.id=170&message.id=159405
Message 14 of 21
(7,450 Views)
I was showing something in LV8 to a colleague and as always something went wrong. He asked me about arrays, I put a build array in a diagram and want to expand this build array with the mouse (as usual). Easy, euh NO I tried everything but expanding the build array, concatenate string or cluster function was only possible with the right mouse menu.
Afterwards I looked further into it. I know that there was an other VI running. I stopped this VI and tried again. Now the expand was working again.
This problem does not exist in LV7.
Message 15 of 21
(7,427 Views)
LV PDA 8.0 doesn't work properly with multidimentionnal arrays and there are probably some other related bugs...
Chilly Charly    (aka CC)
Message 16 of 21
(7,404 Views)
As confirmed by Darren, this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=167942
documents a bug with the "get Image" method of a cluster that also affects other functions that use that method.
Ben
Message 17 of 21
(7,372 Views)
Selecting "Show Control" on constant cluster crashes LabView
I am the founder of CnCSoftwareSolutions. When not cleaning up baby drool, I write about test data or work on Vision, a tool for understanding your test data. Visit me at www.cncsoftwaresolutions.com
Message 18 of 21
(7,315 Views)
Replacing a shift register with tunnels leaves a bogus tunnel in place of the unwired half of the shift register pair. The VI is broken without any error showing when clicking the broken run arrow.
Message 19 of 21
(7,267 Views)
Page 20 "Instrumentation Newsletter" "First Qarter 2006" in the article entitled "Help Define the Next Generation of LaVIEW" includes a section labeled "Discussion Forums".
That section include the following statement;
Active discussion forum members have inititated a monthly thread to capture potential bugs in a single thread.
I would like to thank everyone that has contributed to this thread and helped to make this a reality.
Ben
Message 20 of 21
(7,233 Views)
