BreakPoint
LabView vs LabWindows/CVI
@smercurio_fc wrote:
OK, so what was the original point of this thread? Smiley Very Happy
Still exploring LV vs CVI but now taking a side track to try to C the differences between those that C and those that don't C.
Ali65 wrote;
Ben,
2 Software could be used by not experts? Usually not
1 It depends on the area of use. The software what is used to design a nuclear reactor, should only be used by a small group of experts. The same software if used to design a flyer about a missing dog, should be used by large group of experts.
I cannot recognize OR relationship between 1 and 2.
Ali
Yes I understand that was not a formal "OR" condition. My intent was to learn how you look at software to help understand you and understand why the disucusion is going two different directions.
From your reply above and your previous I hear you speaking about what software SHOULD be. Christian's reply spoke of what software COULD be.
If I am reading you correctly (probably not but that is part the fun of interacting with people when you can't see their face or observe their body language Smiley Wink ), C and similar dirivatives are close to what you believe software SHOULD be and LV and other graphical languages are simply abomanations that should be quashed before they take root spread or worse, displace C.
Please don't take offense in my attempt to understand your message, please! I do the same thing to my buddies (at least the ones that can stand it).
Ben
Message 101 of 222
(12,907 Views)
@Ben wrote:
... C and similar derivatives are close to what you believe software SHOULD be ...
Not necessary C, but I believe software SHOULD be defined in some text based language. Boxes, icons and lines and similar type of visualizations based on graphics present an overhead which are tolerable only for trivial tasks. I totally agree that some visual type of thinkers can easier remember the algorithm if they saw it in graphics, especially the trivial examples. I am that kind of person too. But I do not agree that this is a good enough reason to pay the extra.
@Ben wrote:
... LV and other graphical languages are simply abominations that should be quashed before they take root spread or worse, displace C....
"displace C"???  Is NI developing LabVIEW using the LabVIEW language? I believe that languages cannot be considered as abominations, even if they are less effective. Lying about them, yes.
Message 102 of 222
(12,896 Views)
Are you sitting down? Yes they are, seriously, no lie.
Not for everything (yet) but more and more of LV is being moved to LV.
Thanks for the interesting discusion!
Ben
Message 103 of 222
(12,892 Views)
So you think that designing and planning a huge program should be done using only linear text, or would a flowchart be more appropriate?
What some people fail to grasp is the fact that a LabVIEW diagram is actually much closer to the final machine code than any text based language can ever be. The compilation does not go through an intermediary step that involves text based code.
Here and here are some links.
It is a horrible abstraction to require the programmer to formulate his ideas as a single long linear monochrome string of printable characters delimited by linefeeds. This is very limiting, but this is what text based code is! Think about it.
Why would you force yourself through such an uncomfortably confined detour when going from brain to silicon???
Like everything, programming has evolved, and for me, LabVIEW has percolated to the top of the list. Show me another language that can run seamlessly also on FPGA (I am sure you like VHDL much better though! :D) and embedded targets.
Our retina is 2D and the human brain is extremely well optimized to recognize shapes and 2D and 3D relationships. Tapping ito this power to device a programming tool is literally a no-brainer :D. After you read a book, do you remember the words or the visual imagination triggered by reading them?
Knowledge and skills have evolved over the centuries and the tools need to evolve too. It would be very difficult to do linear algebra using roman numerals these days.
Sure, text based code had some advantages and 50 years ago it would have been difficult to do graphical programming because of lack of hardware support (display, input, etc.). Text based code is also easier to transmit by telegram. The times where these advantages matter are over!
Message 104 of 222
(12,867 Views)
There are many examples when visualization is good.
I just feel bad if I have to enter or store data or algorithm in visual format.
For that purpose text works better.
Message 105 of 222
(12,854 Views)
@Ali65 wrote:
Don't mind me, I'm just a
Also interesting:
Message 106 of 222
(12,851 Views)
...when the brain goes to silicon without an uncomfortably confined detourSmiley Wink
Message 107 of 222
(12,840 Views)
It is sufficient to quote small sections of a post, and not the entire thing. Keep the thread focused and avoid unecessary duplication. Thanks!
Message 108 of 222
(12,833 Views)
Ben
Ben,
Moving to LLVM, not LV.
http://eetimes.eu/en/open-source-compiler-speeds-code-execution-in-labview-2010.html?cmp_id=7&news_i...
With LabVIEW 2010, the compiler data flow intermediate representation has been further optimized, and low-Level virtual machine (LLVM), an open source compiler infrastructure, has been added to the software’s compiler flow to accelerate code execution.
http://zone.ni.com/devzone/cda/pub/p/id/1177#toc5
http://llvm.org/docs/FAQ.html
The LLVM source code should be portable to most modern UNIX-like operating systems. Most of the code is written in standard C++ with operating system services abstracted to a support library. The tools required to build and test LLVM have been ported to a plethora of platforms.
Some porting problems may exist in the following areas:
  • The GCC front end code is not as portable as the LLVM suite, so it may not compile as well on unsupported platforms.
  • The LLVM build system relies heavily on UNIX shell tools, like the Bourne Shell and sed. Porting to systems without these tools (MacOS 9, Plan 9) will require more effort.
Ali
Message 109 of 222
(12,825 Views)
You need to distiguish two different aspects:
  • What was used to write some of the compiler tools.
  • What happens to your LabVIEW diagram code when it gets compiled.
Right?
Message 110 of 222
(12,808 Views)
