BreakPoint
LabVIEW journey starting point
My memories of my first few days with LabVIEW are forever linked to people gathering in the lab, where we had a television, watching the events of Sept.11 take place. Smiley Sad
Richard
Message 41 of 47
(5,225 Views)
On a brighter note, this page started it all for me - just wanted to get a small job done.  Never knew I'd keep doing LabVIEW for 8+ years.
Richard
Message 42 of 47
(5,222 Views)
Which version is this one?? Look at the menu items and those fonts. Just like a turbo c??
Message 43 of 47
(5,217 Views)
Version 5.1 - a classic. Look at the pre-VISA serial port VI's! I got so used to that VI interface, I held onto those old serial port VI's well into LabVIEW 7.1.
corrected: I was using 5.1. That looks even older, doesn't it?
Message Edited by Broken Arrow on 04-08-2010 09:35 AM
Richard
Message 44 of 47
(5,212 Views)
I started with 6.1 and i can see the leap. To begin with the icons were colored, Is that "Temperature plot" a local variable? I still remember everytime disbling the auto tool selection and tabbing to get the required tool in 7.0.
Message 45 of 47
(5,202 Views)
Some of use still tab. Smiley Wink
Richard
Message 46 of 47
(5,196 Views)
I began using LabVIEW since version 5.1 (sometime in 1999)
The task was to create a software program that reads signal from a displacement sensor for checking run-out (CW/CCW) of given shaft bearings. The software program was to read the signal, convert and process it, and plot it on a graph (which will then be saved).
The reason for such software program was to replace the then existing tester/ checker that prints the graph unto carbon paper, which causing problem in keeping/ tracing records. The carbon paper also produces unwanted "powder" when tearing it off.
I was first asked to try it out with VC++, which I wasn't (and still not) good at it 😛 It took me at least two weeks and I was still on a blank sheet... It happened that NI was promoting it newly launched (if I am not wrong) LabVIEW 5.1 and its engineer came over and put up a impressive demo about LabVIEW...
That was how I got started with LabVIEW... and the software program was completed (together with the air-bearing hardware setup) within three months time-frame... worth to mention that learning of LabVIEW was OTJ!
End of my story 😉
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 47 of 47
(5,138 Views)
