BreakPoint
Fog Creek Software (Fogbugz and Kiln)
I have casually used Fogbugz as a bug and feature tracking tool for personal side projects, and I am considering using Kiln, their new source control repository system.
Does anyone have experience with how well these project management systems work with LabVIEW (or another non-text-based language)?
(9,092 Views)
You may wish to post this to the JKI forums (or to LAVA), as I believe they use it.
___________________
Try to take over the world!
(9,066 Views)
I'll scour those forums, then post and link back here next week. Thanks, tst.
(9,060 Views)
Kiln is a service for Mercurial (with probably some added services). I have documented my settings for Mercurial at the LabVIEW Wiki.
Please add your info and experiences there!
Ton
My LabVIEW Ideas
(9,017 Views)
Ton, excellent links, thank you.
(9,011 Views)
For anyone making the switch from SVN or CVS, the links Ton provided are certainly a must-read. I had set up Mercurial mimicking behavior I was accustomed to with CVS, and whaddaya know, commands I "thought" I understood did not behave like I expected. The concepts of local vs. remote and commit vs. push for repositories are unique to Mercurial, and this feature solves a problem that has always bothered me: protecting my code with revision control, while protecting others against my code.
The main reason I went with Fog Creek for this side project is because they are a reputable company with a free turn-key product that I'm pretty confident is going to be developed and supported for years to come. It does not support any LabVIEW IDE integration, but that's fine for now. I have found Kiln good for only one thing so far: having a reliable, hosted backup of the project (which is all I need it to do). Fogbugz is spectacular, but pretty overkill for what I'm doing. I like to use it for keeping notes on features I might work on, and archiving auto-generated emails from program errors/exceptions. In the future, I plan to use the email system as a public bug/feature communication line.
Overall, I would recommend these turn-key easy-to-configure products, but that's coming from a thus-far casual user.
(8,912 Views)
