BLT for LabVIEW (Build, License, Track)
How to select a build
I renamed the build specifications for a project recently, and then tried to select the build spec so I could build/distribute.
However I can't seem to select the renamed build spec:
I want to simply select one of these and move on - it doesn't need to be analysed because I simply renamed it.  But I can't seem to set one of the build specs in the list to be "default".
Is the only way to do this to run Analyze Builds?  I tried this but get an error:
VI Server is set correctly - I have tested VI Server connection and it's connected.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
(2,763 Views)
Accepted by ChrisFarmerWIS
Hi Chris,
Indeed, you need to first Analyze the Build Specs to be able to select the renamed one.
It seems you're having an issue with the LabVIEW VI Server Connection Responsiveness.
I suggest you try to increase the value of the PingTimeout value as described here:
https://www.studiobods.com/help/bltforlabview/LabVIEWVIServerConnectionRespons.html
Hope this helps, let me know...
Cheers.
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
(2,719 Views)
I am running it on an Azure VM, and it tends to be on the slow side, so that may have been the main cause.
I adjusted ping timeout from 180000ms to 360000ms and it worked this morning.
Christopher Farmer
(2,712 Views)
