 PiDi
			PiDi
			11-03-2023 10:02 AM
Hello, I need to runt XCP measaurements in parallel to UDS communication with ECU on the same interface. I'm using ECUMC and Automotive Diagnostics toolkits for this. Both XCP and UDS communication settings are the same, they use same (custom) baud rate. However, I can't make them both run in parallel, as in example below:
The Open Diagnostics VI returns the error -8001 Automotive Diagnostic Command Set: The selected CAN interface is already active using different settings.
Does anyone know how to make those two protocols run on the same interface?
 ZYOng
			ZYOng
			11-03-2023 10:50 AM
Try using Open Diagnostic on CAN FD.vi instead.
11-03-2023 04:16 PM
 ZYOng
			ZYOng
			11-03-2023 05:32 PM
What if you change the I/O Mode to CAN FD + BRS for both sessions?
11-06-2023 04:12 AM
