Automotive and Embedded Networks
LabView and CANoe
I use CANoe and LabView together. I can read environment variables and signals out of CANoe, I can write environment variables, but I can't write signals? I don't know if it is possible at all? I use VIs which I get from Vector Informatik.
I hope anyone knows a solution or maybe knows a website where i can have a look!?
THX
(9,771 Views)
I had a look inside our database but did not find any further hints as well. As far as I found out, there should be some ActiveX control that can be used to transfere data but I suppose that the VIs you got from Vectur are using just this interface.
Maybe somebody else has experience with this topic? I would contact Vector and ask their support as well.
Ingo Schumacher
Application Engineering
(9,769 Views)
can you please tell me how to read environment variables of CANoe in Labview
(4,483 Views)
I can read the environment variables using sample vi provided by Vector I cannot able to read the signal always it is giving as 0 I used the format also as database::network node::message name::signal name could you please help me on this
(4,449 Views)
Hi, I was wondering if you solved this problem? Now I have the same problem you have.
(3,722 Views)
Try something like this here.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,533 Views)
