03-18-2012 02:10 PM
Hi:
I have read this question before but I can´t open the link, when I try to download the solution I get the following : HTTP Status 404 The requested resource is not available.
Can anyone help me with the solution ? I just want to put a header for each column (thermocouple 1, thermocouple 2, anemometer , etc).
In advance, thanks for all your help !
Solved! Go to Solution.
03-18-2012 06:26 PM
There is a Problem with Attachments.
How are you working with Excel now? Are you using the Report Generation Toolkit, ActiveX commands, or just creating a text file with Write to Spreadsheet File that is being imported into Excel?
03-18-2012 06:59 PM
Hi Ravens, first forgive me, I'm not very familiar with the forum. Im just creating a text file with Write to Spreadsheet File that is being imported into Excel.
Thanks for your help.
03-18-2012 07:12 PM
You can use the Write to Spreadsheet File set for strings. Write an array of strings into the 1-D input where each element is a header to one of your columns. Wire that to another Write to Spreadsheet File for you data (with append mode set to True.)
You can't change column widths. Write to Spreadsheet File has nothing to do with Excel. It just outputs a text file that is formatted in a way that Excel can import. The text file won't contain anything that deals with the formatting features of a spreadsheet such as column width. You need to do that in Excel.
03-18-2012 07:39 PM
Im trying but i can´t I dont understand exactly how I have to wire one Write to Spreadsheet File with another Write to Spreadsheet File. 😞
03-18-2012 08:34 PM - edited 03-18-2012 08:34 PM
Perhaps you need to take some tutorials.
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
03-18-2012 08:54 PM
thanks for your help Raven.
Other question, do u know how make this action using ActiveX commands? Please !
Thanks !
03-18-2012 09:07 PM
Search the example finder for Excel and also ActiveX.
Also look through all the links that are posted in the Excel Board. (Don't post questions there, it is a collection of links to other threads discussing excel.)
03-18-2012 09:18 PM
Thanks for all your help Ravens.
