08-10-2012 08:25 AM
I made a LabVIEW project that works perfectly and made an installer for it. I tested the installer on my own computer and everything worked well. The goal for my installer was to put it on multiple computers. So I tried to do this on another computer that has Vista 32-bit and it told me that the installer can only run on 64-bit computers. I tried to choose to install run-time 32bit and it did not change anything, there was still a message to tell me that this installer only can be ran on 64-bit computers. How can I make an installer that works on 32-bit computers?
Thank you.
08-10-2012 08:36 AM
I betieve that you need to install the x86 32bit version on your PC too and build an installer from that.
08-10-2012 08:36 AM
I'm guessing you are using a 64-bit LabVIEW. Have you tried building the installer with 32-bit LabVIEW?
08-10-2012 08:57 AM
No, I did not try it, and yes I have the 64-bit version of LV. Will my project work on 32-bit version even if created on 64-bit version?
08-10-2012 09:06 AM
The code will have to recompile, but yes it should work. I recommend making a backup before proceeding just in case.
