A WONDERFUL idea. This is very tedious to set manually. I use a lot of queued state machines with string state names, and it is a pain to continually set array elements manually.
Wiebe, check my last post on here. In that duplicate idea it was marked as implemented in 2020SP1, albeit an option, with cryptic naming, that actively needs selected in the settings.
ConnerP: What do you mean as an option or cryptic naming? You drop any array containing a text field control (numeric, string, path, etc) in LV 2020 SP1(or later):
AQ, I am not fortunate enough to be running 2020SP1 or newer yet so I could not test the actual experience. Since 2021SP1 has finally dropped I will be talking with my admin about upgrading our systems. My comment was based on Darren writing "Note that this functionality requires that you have Tools > Options > Environment > General > Lock automatic tool selection" in the post I linked.
Ctrl+Enter inserts an item in an array in LabVIEW 2020 SP1 and later.
