I am not sure whether this is a bug or not but when you add a folder containing a X-Control Library to User.lib the auto-generated Controls Palette does not show the X-Control!
It only contains the Data control, State control and any other custom controls (e.g. in the example below StateDisplay is a typedef I created).
There is no way to drag and drop the X-Control in from the Palette - it has to be done from disk!
My idea is that the User.lib auto-generated Controls Palette should show any .ctl, .ctt or .xctl file.
