To replace a VI or a control by an other one from the hard disk a lot of mouse action is necessary (See the first image). An other disadvantage is, that the file browser opens in the last used folder. It would help to start browsing on definable paths.
If the "replace"-context-menu would be extended in the suggested way the "select a VI" function could be reached much faster. Additionally some useful entrees could be added to make replacing even more comfortable.
"Recently used ..." a palette with the last twenty VIs / functions / controls (was already suggested in other ideas)
"Favorites ..." a user definable favorites palette with VIs / functions / controls (was already suggested in other ideas)
"Select a VI..." moved one level up from "All Palettes" and opens a file browser with the last used path
"Browse in <path>" Opens a file dialog at the specified position; Entry(s) should be configurable.
