About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Drag & drop to replace
Currently to replace something (for instance a node on the block diagram) you have to right-click and then select Replace... and then usually a lengthy navigation into the function palette or onto the disk with the OS file explorer.
Most often I already have a LabVIEW-project open, one or more explorer windows (opened at a useful context), and maybe also one or a couple of pinned sub-palettes - but I am not allowed to replace anything from these locations. I suggest that this will actually be allowed; that is: drag something onto the block diagram, and if you're enough on top of another object, then a replace-outline appears for you to drop your new object into. Here's an illustration for replacing something in the block diagram, but the same could apply to the front panel as well:
All the usual stuff should happen when you replace this way, as if you replaced through the context menu. For instance a prompt to save a VI that leaves memory, automatic update of a project's dependencies etc. Many ideas are submitted to this Idea Exchange to enhance the Replace context menu in different ways, but a feature as I'm suggesting here would improve my own workflow the most, simply because I already have much quicker access to my "replacer", through existing explorer windows, than going through the Replace context menu no matter how intelligently it gets populated.
Cheers,
Steen
CLA, CTA, CLED & LabVIEW Champion
10 Comments
I have cursed the lack of such a feature many a time.
Trusted Enthusiast
Trusted Enthusiast
Meanwhile I'm using QD's "Ctrl + P" option.
I also use "Quick Drop", but sometimes it would be more effective do it this way .
Jonathan Cruz
INGENIERIA DE SERVICIOS Y DESARROLLOS
K U D O S __ B I E N V E N I D O S
Quick Drop doesn't let you drop in something from a project nor an open explorer window. It works for palette items if you remember their names.
Don't get me wrong, I'm all for even more intelligent population of the Replace context menu, as well as for QD. I just think this feature is so basic that it should be available too.
/Steen
Trusted Enthusiast
To be fair, project items are available in QD, and you can replace with them using the Ctrl-P default shortcut.
Sorry, I didn't know that (about QD and project items). /Steen
Suggestion:
What if Quick Drop had the possibility of "click to select", for all of us who can't always remember the names of the things we want to drop?
  • Such a feature would allow you to open QD and then click on an item from the project (or any open library), and that item would instantly become the selected QD item.
  • Then you could insert, replace, etc... all from the QD interface.
(Should that be a new idea?)
Chris Virgona
@fabric: That should probably be a new idea, as it definetely isn't an alternative for my suggestion here (for me at least).
/Steen
I also think your idea is much better! (Easier and more intuitive...)
That said, Darren is usually pretty agile with QD enhancements, and adding a click-to-select feature would likely be quite realistic to add for the next release. Your idea (- although superior!) would require mods to the IDE, and NI has a lot of inertia there...
Anyway, I'll post it and see! Smiley Wink
Chris Virgona
Active Participant shb
Similar idea: Copy and Paste Replace
