It would be really cool if LabVIEW had a String Control with inbuilt Spell Checking functionality available at Run Time.
End users will be able to correct input data whilst developers would not have to implement anything (except for maybe enabling spellcheck as a Property of the String Control) as it would all be handled under the hood.
I am thinking that it would look similar to the operation below:
The standard functionality of spell checkers in browser apps (e.g. IP Board) would be sufficient. The above example is from IP Board's editor and the implementation appears clean and fits the workflow well.
There are two other spell check Ideas here and here but the ideas/discussions are about spell checking in the IDE - this Idea is for Run Time.
Note: This idea could be expanded to other use cases however, the above is my primary one. And yes I ran spell check on this post to avoid any of those comments ![]()
