Right on the heels or Darren's idea, here's a related issue along the same lines that has bugged me for years. I think the same arguments (and more!) apply here also.
When opening the front panel of an express VI, I suggest to get rid of that warning dialog shown here.
The warning is wrong, because I can just go to the main VI and press "undo" to get the old configuration dialog back, including all customized values. This is not a dangerous one-way operation as one might think from the wording of that dialog!
At the same time maybe the right-click menu should be clarified. Instead of the innocent "open front panel", it should read "convert to regular VI" or similar, because that's what it mostly does. Opening the front panel after conversion is just an additional convenience. 😉
