To compress the BD add a vertical sequence like structure where all frames run independently and in parallel. As soon as inputs being used for a given frame are present, that frame executes. I foresee some input tunnel properties where a tunnel could be assigned to one or multiple frames. Tunnel props could authorize a frame to start execution even though all data hasn't arrived at the structure. This structure is just for visual compression in the BD.
