This is a little annoyance of mine when I want a shortcut to create a Control (and it doesn't behave as expected)...
...when I popup on an Indexed Output Tunnel of a For Loop and select Create Control LabVIEW always creates a scalar Control, it is only when I select Create Indicator do I get an array (which I then convert to a Control). If I wanted a scalar Control I would popup on the scalar wire.
Thanks for listening 😉
