I very commonly use the Ctrl-Drag shortcut across empty block diagram space to create new space on the diagram. When I do this, it is almost ALWAYS intended to just create space in one dimension, horizontally or vertically. If you dare try to create space in both directions at once, this invariably disrupts the arrangement of the diagram. You end up with objects that were nicely aligned being a few pixels off, or worse.
To create space in one direction, I have to very carefully make sure when I Ctrl-Drag that I stay exactly in a straight line, making the process tedious and error-prone. I often have to undo the operation and start over because I'm one pixel off. (One pixel is a lot in LabVIEW!)
It would be very very beneficial to have a similar shortcut that only operates in one direction, or to be able to specify in Tools>>Options to modify the existing behavior, because the default is never what I want.
Available in LabVIEW 2015 and later
