First of all, this is not a duplicate of this, by Case Selector I mean Case Selector and not the label. It may well be a duplicate of something else...
I doubt that I am the only one who uses multiple conditions. This usually leads to nested Case structures, building boolean arrays, or obfuscated mapping functions between the conditions and some enum. Other times, the case structure is half-of-a-screen wide just to accommodate the values associated with the different cases. I would suggest that NI add multiple Case Selectors to the Case structure. Additional selectors could be pulled down like a shift register, or added via a right-click menu. Either way, I don't think they should be allowed to cross, so the top-down selectors map to left-right selector labels. There could be a reasonable limit to the number.
