User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
This idea is all about culling clicks.
Example:
I have created a subVI based on another VI and I realized that I needed some additional input from the calling VI to perform the task within the subVI:
Since I want to get the right data structure, I can't really create a Control within the subVI, add it to the connector pane and connect the corresponding data from the calling VI.
So I need to:
1) Go to the calling VI
2) Drop a dummy Sequence structure on the BD
3) Pull a wire from the data structure I want to connect to the subVI and connect it to the dummy Sequence
4) Create a subVI from that sequence
5) Copy the resulting control on the subVI's panel
6) Destroy the temporary subVI (that involves a "Do you want to Save this VI?" dialog, so it is really a two-step process)
7) Go to the target subVI
😎 Paste the Control
9) Connect the control to the Connector Pane
10) Go back to the main VI and connect the data
What I suggest is to replace all these steps by a 2-step process:
1) Pull a wire from the data source
2) Bring that wire OVER the target subVI and by a magic combination of keypress and mouse click (for instance "I" for "Insert" and a Right-Click), open up a dialog allowing me to connect that wire into an available connector on the target subVI (a Control being created in the process - I am fine with having to convert it to an Indicator later).
Basically, this "action" would provide access to the connector pane of the subVI with an automatic creation of a control upon clicking on the connector. Existing rules for Control name generation would be fine.
Something like that:
The interface could switch from the subVI icon view to the connector pane view, for instance.
I find myself wanting this alot for things as simple as passing a Graph reference to a subVI, where I want the reference to correspond exactly to the graph type.
