This is something I have wanted for a while now, but I have raised this idea following on from this community thread: https://decibel.ni.com/content/groups/large-labview-application-development/blog/2011/03/16/integrat...
The LVCompare.exe takes in a few command line options for example to ignore front panel changes, if you want compare two VI's but be able to change the switch options you send to LVCopmare you need to write some kind of wrapper function and each time you want to change the difference you see you have to close the Differences window restart the compare again.
I would like to see on the "Differences" window a table that allows the user to change the selected switch options & to then allow the user to re-run the compare on the two VI that are currently in scope without having to close and start again
cheers
Dannyt
