jgcode
Add an "'Explain Error" pop-up menu on an error in an array
Status: New
I did a search for explain error - I did find this idea which is similar but for probes.
Explain Error is a feature I have been using more lately but its not available for an error that is in an array (LabVIEW 2010).
It would be great if it was!
Cheers
-JG
Certified LabVIEW Architect * LabVIEW Champion
5 Comments
JackDunaway
Trusted Enthusiast
Also does not appear when the error cluster is within a cluster or class private data.
jgcode
Good call Jack.
Probe, Array and Cluster would all be very nice.
AristosQueue (NI)
NI Employee (retired)
A more than reasonable suggestion.
_carl
15 years later, and just came here to make the exact same request!
wiebe@CARYA
Knight of NI
Array elements might be a bit hard(er) than errors in clusters but this can probably be done in a (community) shortcut menu plug-in.
