User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
A typedef control has no block diagram. When you modify an existing typedef, block diagram instances of that typedef are updated; but any block diagram display customization is lost. This can seriously affect the appearance of a block diagram when the typedef is inside a state machine.
I suggest that a typedef control should have the ability to define the block diagram appearance, and that it should have it's own flag for regular or strict. A typedef could be defined as regular for the front panel while the block diagram could be set as 'strict'.
The typedef editor could display the front panel and block diagram appearance in adjacent panes (see image below).
