This is only a wish that NI could provide a Utility that converts a VI or Dir to Up or Down.
I had a project that was done in LabVIEW 5 (done many years ago by someone else); I couldn’t open in LabVIEW 8.6. I needed to do stage upgrade LabVIEW 7 and follow up with LabVIEW 8.6 and so on.
I understand there are cases that you can not simply down convert, because newer function may not be available in older version. In this case it OK, give user an option for force the convert and worse case the down convert VI is broken. Let the programmer fix it!
The utility should have a Status Report for convention.
Please..!
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/A-separate-utility-software-for-Upconverting-and-Down...
