High-Speed Digitizers
5922 5124 Fuse rating , output spec of 5V @ 9-pole mini DIN AUX connector
I can't find the specifications of the +5V output (Pin 1 to Pin 2 GND) on the scope cards 9-pole mini DIN connector
Greetings from Germany
Henrik
LV since v3.1
(5,386 Views)
answered here
Henrik
LV since v3.1
(5,374 Views)
The fuse used on the 5V power line in the DIN AUX connector on the 5922 is 1.10A resettable fuse.
I hope this helps!
Edit: Ah, found the answer before I could look it up! 🙂
Systems Engineer
SISU
(5,371 Views)
